Creating Ax, Iy, Iz section
Dear Autodesk community:
Good afternoon
I hope everybody is fine
I would like to explain the following problem that recently appeared when I was trying to create Ax, Iy, Iz steel section through Python-Dynamo nodes. Based on a script found in this forum, I created a special script to create Ax, Iy, Iz sections linking values as free values to the code. Despite the script creates the section within the robot interface, the value defined for Iy is 0 when the values should be 1000 (this is just a number, it was defined with number nodes from Dynamo).
Can everyone help me to fix the script, please?. I am novel using the API from Autodesk Robot, but I understand some concepts due to I read the guide for API.
I attach some pictures to show the visual programming script and the Python script created in this case.
import sys
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
clr.AddReference('DSCoreNodes')
clr.AddReferenceToFileAndPath(r"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2022\Exe\Interop.RobotOM.dll")
from RobotOM import *
dataEnteringNode = IN
SectionName = IN[0]
SectionIy = IN[1]
SectionMaterial = IN[2]
robapp = RobotApplicationClass()
rproject = robapp.Project
rstructure = rproject.Structure
rlabelserver = rstructure.Labels
rselectionfactory = rstructure.Selections
rloadcaseserver = rstructure.Cases
sectionlabel = rlabelserver.Create(IRobotLabelType.I_LT_BAR_SECTION, SectionName)
sectionlabeldata = sectionlabel.Data
datatype = IRobotBarSectionType.I_BST_STANDARD
sectiontype = IRobotBarSectionShapeType.I_BSST_UNKNOWN
rlabelserver.Store(sectionlabel)
nonst_data = IRobotBarSectionNonstdDataValue
nonst_data = sectionlabeldata.CreateNonstd(0)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_AX, 0)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_AY, 0)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_AZ, 0)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_IX, 1)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_IY, SectionIy)
nonst_data.SetValue(IRobotBarSectionDataValue.I_BSDV_IZ, 2)
MaterialName = SectionMaterial
OUT = SectionName, SectionIy, SectionMaterial
Stephane.kapetanovic
hi @Anonymous
First step, try add this line
sectionlabeldata.CalcNonstdGeometry()
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Hi @Stephane.kapetanovic:
Thanks for your recommendation, I appreciate it. I will test your solution.
Best regards
Good afternoon
I hope you are fine
I have added the code line suggested by you, but the problem continues. The section is created within the robot interface but the structural parameters such as Ax, Ix, Iy, Iz still appear void (Zero). Despite I defined with other values in dynamo.  Can you recommend me another alternative, please?. I am sorry for the trouble.
Best regards
PD: I attach images where I expose the problem:
hi @Anonymous
try this.
SectionName = IN[0]
SectionIy = IN[1]
RLabelServer = RobotLabelServer
RLabelServer = robapp.Project.Structure.Labels
RLabel = IRobotLabel
RLabel = RLabelServer.Create(IRobotLabelType.I_LT_BAR_SECTION, SectionName)
RLabelData = IRobotBarSectionData
RLabelData = RLabel.Data
RLabelData.MaterialName = SectionMaterial
RLabelData.Type = IRobotBarSectionType.I_BST_STANDARD
RLabelData.ShapeType = IRobotBarSectionShapeType.I_BSST_UNKNOWN
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_AX, 0)
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_AY, 0)
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_AZ, 0)
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_IX, 1)
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_IY, SectionIy)
RLabelData.SetValue(IRobotBarSectionDataValue.I_BSDV_IZ, 2)
RLabelServer.Store(RLabel)
Best regards
Good morning
The solution proposed by you has worked so well. I would like to thank you for your recommendations and comments. You have saved my thesis. I will put your name on the acknowledgment section of my potential paper.
Best regards
