Create templates using the API
Jelle.Visser
Jelle.Visser
I'm having trouble with predefined templates in RSA. All the predefined member types, supports and releases just randomly disappear, and others appear. So to combat this, I was hoping I might be able to do this in the API. However, looking through the documentation I can see how to create members, but not how to just create member types, and I would also need to define things in the service menu, and define them as OCBF. We do not want to have to create this anew every time we create a new file.
The following things should be defined in the newly created files through the API:
  • Member types (Name, buckling coeficcient, seismic analysis parameters, service menu)
  • Releases
  • Supports
  • Used Codes (ANSI/ASCE or EC)
  • Seismic variables (ag or SS/S1 and ground type)
  • Load cases
  • Combinations
  • Load to mass conversion
The easiest would probably to do this in VB.NET, since all our other RSA code is in VB, however, C# would be fine too, I wouldn't mind an excuse to transition our codebase to C#. Any help would be greatly appreciated. Searching through the documentation hasn't yielded anything usefull yet, I can find parts about creating loadcases, but most bullet points are still up in the air.
Stephane.kapetanovic
hi @Jelle.Visser
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-tutorial/td-p/3939601
https://forums.autodesk.com/t5/robot-structural-analysis-forum/useful-addins-for-robot-api/td-p/3899...
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Jelle.Visser
Hi @Stephane.kapetanovic,
I've already looked through the API documentation in the SDK directory. And I've looked through both these pages as well. I cannot find what I'm looking for. I want to add member types in this menu:
There I want to edit Buckling parameters, the service menu and seismic analysis parameters:
And that's just the member types. If it is available in the documentation, could you point me in a more specific direction?
Cheers
hi @Jelle.Visser
Steel design - CodeParams[EC8 & Python code][API] Define Membertype Adjoin Params[API] Steel Code Params Buckling Diagram
Best regards
