hi,
I as wondering could somebody tell how to copy elements up from the lowest level further up the building such as wall panels without copying the supports with them. can this be done using the edit copy tool or with the copy storey tool highlighting the elements only to be copied up. I can do it using the copy storey tool as long as its directly on the storey above, however if copying from lowest level to say the 4th floor it does not work. could somebody give me some guidance on how to do this. I have attached pdf explaining. Many Thanks.
S.
Solved by Artur.Kosakowski. Go to Solution.
Personally I'd copy the selected panels with the translation tool and then having the active selection of the copied panels removed the excessive linear supports with one click:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
