Column Geometry
Column Geometry
rasheedalbadwi
Column Geometry
rasheedalbadwi
Romanich
Hi @rasheedalbadwi ,
Did you install hotfix 1 for Robot 2022?
Which design code you are using?
You can also zip the model and attach it.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
rasheedalbadwi
Did you install hotfix 1 for Robot 2022? no i don't know what's that , how can I get this file , will it help?
Which design code you are using? ACI 318
You can also zip the model and attach it.,,,, not specific model, all models that i create is same problem , the problem on the program
Romanich
You can find the hotfix in your Autodesk account
In Robot several revisions of the ACI code have been implemented. Please specify the exact one.
Roman Zhelezniak
rasheedalbadwi
You can find the hotfix in your Autodesk account. can you copy a link plz
In Robot several revisions of the ACI code have been implemented. Please specify the exact one. aci 318-11
Romanich
Hotfix 1 for Robot 2022
I have checked both versions of the ACI 318-11 - no issues on my side. Could explain step by step your actions to reproduce the error?
Roman Zhelezniak
rasheedalbadwi
thank you so much
