How can I have this member only take compression using only linear release?
yiviw97057
yiviw97057
I wanna make sure the member red arrow points to only takes compression; how should I define the linear release to make it so? I wish to do this without using "compression only" members.
Stephane.kapetanovic
hi @yiviw97057
https://knowledge.autodesk.com/support/robot-structural-analysis-professional/troubleshooting/caas/s...
By Taking care to cancel previous members releases
Or this way ↓
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Rafacascudo
Using "Compression only" bars or the method Stephane described will not avoid having non linear analysis ,if is that what you want.
It is automatic
Rafael Medeiros
Simau
@yiviw97057
Usually this type of structure uses tension only guys.
Is there a reason to use them as compression only?
M. Agayr
already solved here
https://forums.autodesk.com/t5/robot-structural-analysis-forum/how-can-i-have-this-member-only-take-...
yiviw97057
Could I ask how releasing Ry and Rz in one end creates a compression member?
It's up to you which is the best. It is useful to show that it is possible to combine bidirectional (RY RZ) and unidirectional (UX+) releases
