- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings everybody. I am losing my mind over this model of a circular multifloor RC building: I have imported the model from Revit 2022 to Robot 2024 and I have been correcting it in order to run the analysis for two weeks now. I have used Delaunay mesh with size 0,5 and with regular option unchecked for all panels, but the model has so many discrepancies that I always get the message about cyclic reference of the kinematic constraints that occurs in ca. 40 places in the model. And because the panels of the walls are curved it is very difficult to correct the model in order to have a correct kinematic constraint where needed. So when I correct some wall I got an error on the other side or height of the wall for example.
Can somebody please suggest the most fitting or robust mesh options for this kind of model? And also how to correct the model in an efficient way and don't lose two more weeks to get the analysis running.
Thanks!
