Can robot2024 open str files?
zongyang_li
zongyang_li
Previously, I could use the program to produce str files which could be opened by robot2020. But now, robot2024 cannot open them, and even the str files generated by robot2024 itself cannot be opened by robot2024. The error message displayed is "errors in the file". What is the reason for this error? Can robot2024 still open str files?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @zongyang_li
I do not think procedure of opening STR files have changed between version 2020 and 2024. Probably error is reported for material not available in Job Preferences (in version 2024)
If you will not be able to solve the problem please share STR file for verification.
Krzysztof Wasik
zongyang_li
Thank you for your reply. I have uploaded the str file. Please check it.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @zongyang_li
This STR opens with no error for English/ UK settings in Preferences and UK material database.
Refer to video
https://somup.com/cOj6jmVnKya
After supports modification model can be calcualted and results are obtained.
You can click in Error message when STR is verified. Probably it will indicate line with material definition.
Krzysztof Wasik
bhavani_sankuratri
Hi @zongyang_li ,
Hope you are doing good! I wanted to follow up and see if you've had a chance to review Krzysztof_Wasik 's reply. If so, please let us know whether it helped resolve the issue or if you are still experiencing the problem. We look forward to your update. Thank you!
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Bhavani Sankuratri
