Report template
Report template
aleksandra_kawkaWWJ8W
Observer Observer
Report template
Observer
Observer
How can I add a new item to the report, with a heading and text only, without an image or table? The “Eigenvalues” component is not sufficient because the heading does not appear in the table of contents.
Stephane.kapetanovic
hi @aleksandra_kawkaWWJ8W
Naturally, when you are prompted to capture the table, you can rename it, add a comment, etc. This title is then used in the printed calculation report.
This title can be modified at any time from the Print Composition Wizard.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
bhavani_sankuratri
Hi @aleksandra_kawkaWWJ8W ,
Hope you are doing good! I wanted to follow up and see if you had a chance to review Stephane.kapetanovic 's suggestion. Please let us know if this helped answer your question or if you need any further assistance.
Bhavani Sankuratri | Community Manager
