I'm modelling an industrial building by RSAP. But I didn't model any purlin to this building. Can I assign the influence of purlins into steel rafter and column; or I have to model it to?
Solved by saclovitzky. Go to Solution.
Thanks.
You can put restraint into the rafter/beam without modelling purlins.Pls. see attached
@Anonymous @saclovitzky
be aware that the restraints concern only purlins linked to roof bracing nodes
M. Agayr
