Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Punching shear capacity
2 REPLIES 2
673 Views, 2 Replies
I'm a student and I'm not really experienced using Robot Structural. During doing a simple small project I realized something that doesn't make sense to me about punching shear. In the same project I tried to use 30x30 cm columns and the slab failed by punching shear, but using 25x25 cm it have the enough capacity for the structural requirements. Why this happens? Isn't having a column with a larger area supposed to increase punching shear capacity?
I leave attached the results with both sections.
I will appreciate your help and guideline!
Labels (2)
2 REPLIES 2
Krzysztof_Wasik
Hi @Anonymous
For column 25x25 program was able to define reinforcement for punching. For column 30x30 critical perimeter is smaller (probably due to column position in edge/corner region) and program cannot define required punching reinforcement.
Krzysztof Wasik
in reply to: Krzysztof_Wasik
I understand. Thanks a lot!
Technology Administrators
