Boolean operation
1 REPLY 1
535 Views, 1 Reply
Boolean operation
I am having a problem with the object combinations. I am trying to make a hole in a panel by using a Boolean operation (subtraction).  The problem is that the operation is keeping the intersection between the two panels. How can I just make a hole in the panel ?
Should I use a projection of a geometrical object ?
I saw on a forum that I could use a contour and click on "opening" in the parameter section but I am using Robot structural analysis 2014 and the box isn't existing.
Thank you for your time.
Tags (1)
1 REPLY 1
Technology Administrators
