After changing claddings to panels instabilities (type 3) appear in panel nodes
Hello RSA familiy!
I need help with my test model.
I want to know stresses and deformations in the bars of my  "base structure".
First when I used claddings to apply loads, then everything seemed to be understandable - I got my stresses and deformations what seemed to be correct.
When I wanted to check how much the thin plate (what is connected by bolts with the beam elements) affects the deflections of the beams and whole structure - then the problems appeared.
I gave to the claddings thickness and by that I changed claddings to panels.
But now I get during the calculations instability warnings about the nodes locating inside the panels. I have tried for testing purpose to add for specific node a support, but during the next calculation I get new instability warning with new node.
I would be very thankful when someone could explain me what I am doing wrong.
Best Regards,
Maarjus
Rafacascudo
It seems that nothing is wrong with your model as node displacements are probably compatible with the structure modelled.
Take a look on webinar 16 on Build your Robot Structural Analysis IQ - YouTube and also on several forum messages about instability type 3.
Also,
1-You have analysis warnings that you should check . Ix=0 probably because you forgot to mark Ix calculation on section definition module. There is also a compatible nodes warning.
2- Mesh size is probably too small . This affects analysis time and displaying of results . Some panels display different mesh pattern .
3- Load DL1 has no loads applied.
Rafael Medeiros
Thank You!
Your answer helped to solve the instability problem!
Best Regards!
Maarjus
