Hello RSA familiy!
I need help with my test model.
I want to know stresses and deformations in the bars of my "base structure".
First when I used claddings to apply loads, then everything seemed to be understandable - I got my stresses and deformations what seemed to be correct.
When I wanted to check how much the thin plate (what is connected by bolts with the beam elements) affects the deflections of the beams and whole structure - then the problems appeared.
I gave to the claddings thickness and by that I changed claddings to panels.
But now I get during the calculations instability warnings about the nodes locating inside the panels. I have tried for testing purpose to add for specific node a support, but during the next calculation I get new instability warning with new node.
I would be very thankful when someone could explain me what I am doing wrong.
Best Regards,
Maarjus
Solved by Rafacascudo. Go to Solution.
It seems that nothing is wrong with your model as node displacements are probably compatible with the structure modelled.
Take a look on webinar 16 on Build your Robot Structural Analysis IQ - YouTube and also on several forum messages about instability type 3.
Also,
1-You have analysis warnings that you should check . Ix=0 probably because you forgot to mark Ix calculation on section definition module. There is also a compatible nodes warning.
2- Mesh size is probably too small . This affects analysis time and displaying of results . Some panels display different mesh pattern .
3- Load DL1 has no loads applied.
Rafael Medeiros
Thank You!
Your answer helped to solve the instability problem!
Best Regards!
Maarjus
