Hi @HoshangMustafa
Ok, i see you want to create Revit model based on Analysis model in Robot
It can be done through following steps :
1- Install Extension For Revit And Robot Structural Analysis.exe
2- Open empty Revit file
3- Open your final Robot model
4- In Revit, create update model from Extension For Revit And Robot Structural Analysis.exe
5- In Revit, Analytical model is present
6- From Analytical Automation, convert the model from Analytical to physical and select all model elements
7- Finally, your physical model is present
8- You can make additional alignments and adjustment in Revit
All of these steps are shown in this tutorial
Please, @HoshangMustafa , accept as as solution if you find your answer.
