Autodesk Robot integration with Revit
HoshangMustafa
Advisor Advisor
Message 1 of 24
HoshangMustafa
Hi all,
I'm using ARSA 2026. How one can use the integration tool to send an ARSA file to Revit?
Replies (23)
Message 2 of 24
Mohammed_Ata
Hi @HoshangMustafa
You can download (The Integration Extension for Revit and Robot Structural Analysis 2026) and install it them, export from revit to robot as explained in this tutorial
You can use either (1) direct integration or using (2) intermediate file (smxx)
Message 3 of 24
HoshangMustafa
Hi @Mohammed_Ata
So, I have modelled and designed a structure in ARSA and I want to send it to Revit. How would you do that using ARSA 2026 and Revit 2026?
Message 4 of 24
Mohammed_Ata
Hi @HoshangMustafa
Ok, i see you want to create Revit model based on Analysis model in Robot
It can be done through following steps :
1- Install Extension For Revit And Robot Structural Analysis.exe
2- Open empty Revit file
3- Open your final Robot model
4- In Revit, create update model from Extension For Revit And Robot Structural Analysis.exe
5- In Revit, Analytical model is present
6- From Analytical Automation, convert the model from Analytical to physical and select all model elements
7- Finally, your physical model is present
8- You can make additional alignments and adjustment in Revit
All of these steps are shown in this tutorial
Please, @HoshangMustafa  , accept as as solution if you find your answer.
Message 5 of 24
WALIDGIO
you can do it only from Revit, from an empty file and click update model
it will bring the Robot model to Revit analytical, then convert it to physical model
Message 6 of 24
WALIDGIO
I have one big problem, in robot if you have a cladding and convert it to normal panel, Revit will not bring it, do you have solution to this?
Send model from robot to Revit (cladding problem)
Message 7 of 24
HoshangMustafa
Hi @Mohammed_Ata
I'm using ARSA 2026. I couldn't manage resizing the ARSA program to make it side-by-side with the Revit program. How it can be done? I mean resize the ARSA program main window.
Message 8 of 24
WALIDGIO
Is this what you mean ?
(view in My Videos)
Message 9 of 24
datpt_nuce
Community Visitor
Community Visitor
Hi, the exe file you sent is an extension for Revit Robot 2025. Could you please send the extension file for Revit Robot 2026? Thank you.
Message 10 of 24
Mohammed_Ata
@datpt_nuce
You can download it from this attachment
If you find your answer, please accept as solution
@HoshangMustafa
@datpt_nuce
Message 11 of 24
datpt_nuce
Community Visitor
Community Visitor
thank you so much, It 's working!!!
Message 12 of 24
ISDI1
Community Visitor
Community Visitor
Hi, could you also send the link to Robot 2024?
Message 13 of 24
joseph_e
Observer
Observer
Hi, I am having issues viewing the reinforcement after sending it back from robot structures 2026 to revit structures 2026. Can you help me sort it out
Message 14 of 24
ivanmichel930511
Observer
Observer
me sucede lo mismo, y en robot no me habilita las opciones para el enlace directo
Message 15 of 24
haidara_7f
Community Visitor
Community Visitor
please u have 26 version ?
Message 16 of 24
ivanmichel930511
Observer
Observer
 Yes, I have 2026 version
Message 17 of 24
Mohammed_Ata
You can download for version 2026 from here
Message 18 of 24
nomenafeK2AM5
Observer
Observer
May I have the 2027 extension
Message 19 of 24
Mohammed_Ata
Hi, You cand download it from here
Message 20 of 24
nomenafeK2AM5
Observer
Observer
Thank you.
I appreciate it.
