Send model from robot to Revit (cladding problem)
WALIDGIO
WALIDGIO
hello
I have problem when updating the model from robot to revit when i updated a panel in robot from cladding to a normal concrete panel the revit will not reconize it , why ?
here the steps
1 send a normal model to robot wit a concrete roof
then change the roof to cladding to exercise some analytical calculation,
when finishI change the cladding to a normal panel since the revit dont reconize cladding
then send back the model to revit with the new panel but here the problem
the roof fis empty ???
I tryed a lot of changes to the panel but none worked
can anyone have explanation to this or can help i'll be appreciated
WALIDGIO
Anyone can help  ?
jay_colcombe
Can you share the robot model?
Jay Colcombe
Autodesk Certified Instructor
WALIDGIO
hello,
I did use a simple model created just to show this problem , in a particul model, you cad try it bby creating any model it will have the same problem
jay_colcombe
If you just upload it I have exactly what you have and remove any error with translation which will not help solve the issue!
Jay Colcombe
WALIDGIO
ok here the two model Revit and Robot
the Revit model have analytical wall and floor that have material and thickness
I did send the model to Robot > convert the floor to cladding > then convert it back to normal panel > and here the problem if we make in Revit update the model it will not bring back the floor panel
model attached
