ARSA 2022: DISAPPEARING OF COLLABORATION TOOLS
StefanoPasquini6790
Advisor Advisor
Message 1 of 22
StefanoPasquini6790
Dear Dev team,
Today (2021/06/28) I've installed the latest hotfix for Revit 2022, when I opened Robot I foud this ugly surprise:
all the default apps for comunication with other adsk universe softs are disappeared.
This thing do not happens with ARSA 2021, so, as temporary solution, I use ARSA 2021 to import the advance steel model in robot, then I open the created model with ARSA 2022, but it have to be fixed very very soon....
Could it be somethig that I've done wrongly???
Thank you in advance for your effort, greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Replies (21)
Message 2 of 22
okapawal
Sorry Stefano, seems that you are right.  We will check this.
Waldemar Okapa
Software Quality Assurance & Testing Engineer
Message 3 of 22
StefanoPasquini6790
Hi @okapawal ,
If I try to uninstall the Revit update? Could it solve my problem?
Thank you
PasProStudio
Message 4 of 22
okapawal
Well, weird. I don't see Revit 2022.0.1 Hotfix on the updates list to uninstall.
We have contributed to the Revit hot-fix with some Extension updates.
Maybe it's a matter of some common components registration.  We need to check it.
Waldemar Okapa
Message 5 of 22
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @StefanoPasquini6790
Revit 2022 uninstall did not helped in my case.
Problem was solved in the following way.
- Uninstall Revit 2022
- Uninstall Robot 2022
- Restart system
- Install Robot 2022 (options should be available).
- Install Revit 2022 (do not install Revit 2022 Hot fix 1 )
Krzysztof Wasik
Message 6 of 22
StefanoPasquini6790
Hi @Krzysztof_Wasik ,
First of all thank you for you effort.
This is a very very bad workaround, I didn't yet tried to repair the Robot installation....to get a quickest solution.
Anyway, it's very strange that an Hotfix, that have to solve problems, it create a new big ones. I hope for a quick official solution, such as a new Hotfix for Robot that include all the past bugs....
I'll let you know
PasProStudio
Message 7 of 22
StefanoPasquini6790
sad news, uninstall and reinstall Robot it does not work!!!
PasProStudio
Message 8 of 22
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Have you uninstalled Revit 2022 HF1?
Krzysztof Wasik
Message 9 of 22
okapawal
The problem is caused by the fact that we deliver common components for Revit and Robot.  This component has been corrected and delivered with Revit 2022 Hot-fix 1.
Unfortunately this interfere with Robot 2022, some functionalities stopped working when the component is upgraded.  It includes:
- add-in menu is empty
- steel connection design is not working
- a few dialogs in RC Column design don't open
For the moment the only workaround is to reinstall Revit and Robot to the state before Revit Hotfix was applied.
Please refrain from installing Revit 2022 Hotfix 1 until we publish Hotfix for Robot.
Robot 2022 Hotfix 1 will correct the situation as we will upgrade the component as well.
We are working to deliver the hotfix as soon as possible.
Sorry for inconvenience.
Waldemar Okapa
Message 10 of 22
StefanoPasquini6790
Well, so I'm forced to uninstall and reinstall all....
sad
PasProStudio
Message 11 of 22
AndreNel6007
Hi @okapawal
Any idea when we can expect a hotfix for Robot 2022 to fix this issue? (weeks, months...)
Kind Regards
Message 12 of 22
okapawal
We have a release candidate for the hotfix. We need to test the installation carefully along with Revit.  Then the release process is complex.
I think it will take a couple weeks.
Waldemar Okapa
Message 13 of 22
GatisM
Hello!
Did you solved the issue?
I unistalled both revit and robot, deleted all files on C disk belowing to revit and robot versions.
Reinstalled revit first build version than robot, opened but still missing revit integration.
Message 14 of 22
GatisM
Hello!
In first attempt i just reinstalled revit and robot, but that didn't work.
In second attempt i uninstalled all autodesk softwares, deleted all autodesk folders, all regedit files, did clean uninstall of autodesk compenents. Then installed robot, then revit without any updates, updates are showing as avaliabel in autodesk desktop app, but still no integration option. Maybe you can advice how to bring my revit analytical model to robot environment without remodeling? Or maybe we can manually copy some necesary files to robot installation folders?
I noticed that today 26.07.21. is released issue addin v2.1. for revit, maybe but in release notes there is nothing mentioned about robot integration, must it be installed?
Message 15 of 22
okapawal
Hi @GatisM
When you uninstall Robot and Revit you may need to delete this folder as well:
"c:\Program Files\Common Files\Autodesk Shared\Autodesk Robot Structural Analysis Engine 2022"
Please, wait a while.  The hotfix will be delivered really soon.
Waldemar Okapa
Message 16 of 22
okapawal
This issue has been corrected with Robot Structural Analysis 2022 Hotfix 1.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-2022-hotfix...
Waldemar Okapa
Message 17 of 22
marika.stokkeby
Hi!
RSAP 2022.0.1 Hotfix solved the problem but it stared again
after installing Revit 2022.1 Update.
Message 18 of 22
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @marika.stokkeby
I would uninstall Robot from Control Panel >Programs and features then install it Robot 2022 and then Robot 2022 HF1.
Krzysztof Wasik
Message 19 of 22
I still have this issue after updating all the products (like RSAP and Revit) to the latest versions. I've all the hot-fixes installed.
I've just re-installed RSAP and updates but still the same.
Message 20 of 22
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
According our tests the following installation path can result in problem with addins
This is the critical sequence as Hotfixes were released, and brings the problem:
  1. RVT 2022
  2. RSA 2022
  3. RVT 2022.HF 0.1
  4. RSA 2022 HF1
  5. RVT 2022.1
In this case Robot reinstallation usually helped.
Please see that there are two updates to Revit HF 0.1 (makes trouble) and HF1 which fixes the problems (together with Robot HF1).
The other source of problems can be incorrect Robot installation/registration,caused usually by
- Antivirus setting,
- limited user privileges while software installation
- Microsoft User Account Controll (UAC) option activated.
So please
Check if Revit HF1 (not only Hf 0.1) is installed. If it (Revit HF1) was installed before Robot reinstallation,  I would suggest Revit and Robot reinstallation.
Please try the following
- Uninstall Revit and Robot hotfixes from Control Panel >Programs (at least Robot HF should be available for uninstall in Updates section).
then
- log to account with admin privileges
- disabe UAC option
- disable (temporary) Antivirus system
- reinstall software neglecting Revit HF 0.1 instllation.
  1. RVT 2022
  2. RSA 2022
  3. RSA 2022 HF1
  4. RVT 2022.1
Krzysztof Wasik
