Robot Structural Analysis 2022 Hotfix 1
okapawal
Autodesk Autodesk
okapawal
We have released RSA 2022.0.1 Hotfix 1
It is available through Autodesk Desktop Application and Autodesk Accounts.
This hotfix addresses a major issue in which some functionalities stopped working when Revit 2022 Hotfix 1 has been installed on the same machine.
It enhances reliability and corrects other issues that you may encounter while using the product.
Please find more details in the Release Notes.
Robot_Structural_Analysis_Professional_2022.0.1_HotFix_Release_Notes
Waldemar Okapa
Sr Product Owner
jonas_a14
Essa é a versão atualizada da Hotflix, os erro já foram corrigidos??
clacampos
Olá @jonas_a14
Temos um forum de Robot em portugues neste link com muitos brasileiros que usam o Robot e podem compartilhar com voce as duvidas.
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
MOR-ConorMacken
Why doesn't it fix the Revit Integration?  Or, should I say, the complete lack of Revit Integration?
ignaciomcabrera
Hey @okapawal
I just installed the Hotfix 1. But now, when I try to take any kind of report I have this issue
I tried to save the .rtd file in the location, which apparently it's the solution, but without success. I show you the message.
It said
"file not found
Check the file name and try again"
How can I solve it?
Thanks!
ignaciomcabrera
I already found the solution!
You have to disable the access to folders control on Windows Defender.
Thanks anyways!!
