Member types via API (vba)
anacffaria
Message 1 of 1
anacffaria
I'm trying to create member tipes via API using vba. The work is mostly done but I'm stuck in two situations and I'd really appreciate if someone could help me.
Number 1:
I'd like to access "Adjoining Member Parameters" and input the values in the red boxes (see image attached). If that is not possible, can I know how Robot calculates the value? I've been searching for the method and only found about Wood's method that includes an abacus but maybe it's very dificult to convert into vba (without some error).
Number 2:
I can't thick the "Thin walled element" option. I've searched on the forum and found responses for that but unfortunatelly none has solved my problem.
Thanks in advance for any help.
Ana
Replies (0)
