Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
(API) Speed up API (Extract results)
alfredmx
Message 1 of 22
alfredmx
I need to extract panel node results from multiple model files.
I'm using the following code to extract results:
Dim robotapp As IRobotApplication
robotapp = New RobotApplication
For i = 1 To grid1.Rows.Count - 2
robotapp.Project.Open(vecrutafile(i - 1))
robotapp.Project.Preferences.Units.Refresh()
Dim filename As String
filename = "\" & grid1(i, 1) & "_" & txtfile2pan.Text & ".csv"
Dim objWriter As New IO.StreamWriter(savepath & filename)
Dim RSelection As RobotSelection
RSelection = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_PANEL)
RSelection.FromText(elem)
Dim panelcoll As RobotObjObjectCollection
panelcoll = robotapp.Project.Structure.Objects.GetMany(RSelection)
Dim FileLines As String
FileLines = ""
FileLines = "Panel,Node,Case,UXX (cm),UYY (cm),WNorm. (cm),RXX (Deg),RYY (Deg)" & vbCrLf
For j = 1 To panelcoll.Count
Dim obj As IRobotObjObject
obj = panelcoll.Get(j)
Dim panelnum As Long
panelnum = obj.Number
Dim nodes As String
Dim nodesel As RobotSelection
Dim nodecoll As RobotNodeCollection
nodes = obj.Nodes
nodesel = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_NODE)
nodesel.FromText(nodes)
nodecoll = robotapp.Project.Structure.Nodes.GetMany(nodesel)
Dim FEparams As New RobotFeResultParams
If combolayer.SelectedIndex = 0 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_UPPER
ElseIf combolayer.SelectedIndex = 1 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_MIDDLE
ElseIf combolayer.SelectedIndex = 2 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_LOWER
Else
End If
FEparams.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_UNDEFINED, 0, 0, 0)
For k = 1 To nodecoll.Count
Dim node As IRobotNode
node = nodecoll.Get(k)
Dim nodenum As Long
nodenum = node.Number
FEparams.Node = node.Number
FEparams.Case = caso
Dim FEresults As RobotFeResultDetailed
FEresults = robotapp.Project.Structure.Results.FiniteElems.Detailed(FEparams)
FileLines = FileLines & " " & panelnum & ", " & nodenum & ", " & caso & ","
FileLines = FileLines & Format(FEresults.UXX * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.UYY * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.WNorm * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.RXX * (180 / Math.PI), "0.000") & ","
FileLines = FileLines & Format(FEresults.RYY * (180 / Math.PI), "0.000") & vbCrLf
Next
Next
objWriter.Write(FileLines)
objWriter.Close()
robotapp.Project.Close()
 Next
robotapp.Quit(IRobotQuitOption.I_QO_DISCARD_CHANGES)
The problem is that extracting results for each model is taking up to 8min (larger models with aprox 300 panels and 80 nodes per panel), and total number of models is around 80.
Is there any way to speed up the process?
Replies (21)
Message 2 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 22
alfredmx
Hello Rafal,
Thanks a lot for your help. I will give it a try. Is it possible to have example code in VB?, I'm not very familiar with C++ syntax.
Message 4 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Private Sub CommandButton2_Click()
Dim RobApp As New RobotOM.RobotApplication
Dim Res As IRobotResultQueryReturnType
Dim RobResQueryParams As RobotResultQueryParams
Dim RobResRowSet As New RobotResultRowSet
Dim SelPanel As RobotSelection
Dim SelCas As RobotSelection
Set SelPanel = RobApp.Project.Structure.Selections.Create(I_OT_PANEL)
Set SelCas = RobApp.Project.Structure.Selections.Create(I_OT_CASE)
SelPanel.FromText ("all")
SelCas.FromText ("all")
Set RobResQueryParams = RobApp.CmpntFactory.Create(I_CT_RESULT_QUERY_PARAMS)
RobResQueryParams.ResultIds.SetSize (1)
RobResQueryParams.Selection.Set I_OT_PANEL, SelPanel
RobResQueryParams.Selection.Set I_OT_CASE, SelCas
RobResQueryParams.SetParam I_RPT_MAX_BUFFER_SIZE, 2000000
RobResQueryParams.SetParam I_RPT_SMOOTHING, I_FRS_SMOOTHING_WITHIN_A_PANEL
RobResQueryParams.SetParam I_RPT_LAYER, I_FLT_ABSOLUTE_MAXIMUM
RobResQueryParams.SetParam I_RPT_DIR_X_DEFTYPE, I_OLXDDT_CARTESIAN
RobResQueryParams.SetParam I_RPT_DIR_X, 1, 0, 0
RobResQueryParams.ResultIds.Set 1, I_FRT_DETAILED_TXX
'Set Res = RobApp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet)
'Dim q As New Object
Dim v As Double
Dim max As Double
Dim min As Double
max = 0
min = 0
Do
Dim ok As Boolean
ok = RobResRowSet.MoveFirst()
While ok
v = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(1))
If (min > v) Then min = v
If (max < v) Then max = v
ok = RobResRowSet.MoveNext()
Wend
Loop While Res = I_RQRT_MORE_AVAILABLE
MsgBox ("min = " & min & " max = " & max)
End Sub
Rafal Gaweda
Message 5 of 22
alfredmx
Hello Rafal,
I'm using the following code:
'_____________
Dim RSelectioncase As RobotSelection
RSelectioncase = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_CASE)
RSelectioncase.FromText(Convert.ToString(caso))
FileLines = ""
RobResQueryParams = robotapp.CmpntFactory.Create(IRobotComponentType.I_CT_RESULT_QUERY_PARAMS)
RobResQueryParams.ResultIds.SetSize(5)
RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_PANEL, RSelection)
RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_CASE, RSelectioncase)
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_MAX_BUFFER_SIZE, 2000000)
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_SMOOTHING, IRobotFeResultSmoothing.I_FRS_GLOBAL_SMOOTHING)
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_LAYER, IRobotFeLayerType.I_FLT_UPPER)
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_LAYER, IRobotFeLayerType.I_FLT_MIDDLE)
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_LAYER, IRobotFeLayerType.I_FLT_LOWER)
Else
End If
RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_DIR_X_DEFTYPE, IRobotObjLocalXDirDefinitionType.I_OLXDDT_UNDEFINED)
'RobResQueryParams.SetParam(I_RPT_DIR_X, 1, 0, 0)
RobResQueryParams.ResultIds.Set(1, IRobotFeResultType.I_FRT_DETAILED_UXX)
RobResQueryParams.ResultIds.Set(2, IRobotFeResultType.I_FRT_DETAILED_UYY)
RobResQueryParams.ResultIds.Set(3, IRobotFeResultType.I_FRT_DETAILED_WNORM)
RobResQueryParams.ResultIds.Set(4, IRobotFeResultType.I_FRT_DETAILED_RXX)
RobResQueryParams.ResultIds.Set(5, IRobotFeResultType.I_FRT_DETAILED_RYY)
Res = robotapp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet)
Do While Res = IRobotResultQueryReturnType.I_RQRT_MORE_AVAILABLE
Dim ok As Boolean
While ok
FileLines = FileLines & Format(RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(1)) * 100, "0.000") & ","
FileLines = FileLines & Format(RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(2)) * 100, "0.000") & ","
FileLines = FileLines & Format(RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(3)) * 100, "0.000") & ","
FileLines = FileLines & Format(RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(4)) * (180 / Math.PI), "0.000") & ","
FileLines = FileLines & Format(RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(5)) * (180 / Math.PI), "0.000") & vbCrLf
End While
Loop
'_____________
It seems to be working fine, because "FileLines" captures some results, but at some point within "While ok" loop a COM exception crashes the procees with HRESULT E_FAIL error. Any ideas?
Message 6 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
It works fine.
Try to register Robot as admin.
If it does not help - send us Robot file to check it with this code.
Rafal Gaweda
Message 7 of 22
alfredmx
Hello Rafal,
By register Robot as admin you mean post 8 in this topic, or just "Run as admin"?
http://forums.autodesk.com/t5/robot-structural-analysis/vba-excel-macro-for-any-object-geometry-modi...
Message 8 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
post 8
Rafal Gaweda
Message 9 of 22
alfredmx
Hello Rafal,
Sorry for the delay. I've been busy with an upcoming structural drawings delivery. In the meantime, I've been using current (slow) code to extract results from all model files. I will try suggested solution as soon as I have some free time. Thanks a lot for your help.
Message 10 of 22
Hello, I'm currently trying to get the maximum principal stress inside FE panels and I bumped into the query solution (getting the results with the extreme result server gives inacurate results). I work with VBA from Excel and when I try to create the RobotResultRowSet object I get an error 429. I tried both with early and late binding : - Dim rowset as New RobotResultRowSet - Dim rowset as Object; Set rowset = CreateObject("Robot.ResultRowSet") but they both give the same error on the object's creation. I tried unregistering and registering robot.exe (with /unregserver) as admin, as suggested in other posts but that did nothing I also tried running Robot and/or excel as admin but it dosen't work neither. I even checked the class in the register and "Robot.ResultRowSet" exists in HKEY_CLASSES_ROOT with a supplied class id. Do you have a solution ? Thanks, Regards. PS : To the admin team : Since a few weeks, I can't seem to display the topic list in the forum board, or even create a new post in this board. I tried with both firefox and IE and the result is exactly the same. Is there a workaround ?
Message 11 of 22
Sorry, retrying to post with the right formatrting : Hello, I'm currently trying to get the maximum principal stress inside FE panels and I bumped into the query solution (getting the results with the extreme result server gives inacurate results). I work with VBA from Excel and when I try to create the RobotResultRowSet object I get an error 429. I tried both with early and late binding : - Dim rowset as New RobotResultRowSet - Dim rowset as Object; Set rowset = CreateObject("Robot.ResultRowSet") but they both give the same error on the object's creation. I tried unregistering and registering robot.exe (with /unregserver) as admin, as suggested in other posts but that did nothing I also tried running Robot and/or excel as admin but it dosen't work neither. I even checked the class in the register and "Robot.ResultRowSet" exists in HKEY_CLASSES_ROOT with a supplied class id. Do you have a solution ? Thanks, Regards. PS : To the admin team : Since a few weeks, I can't seem to display the topic list in the forum board, or even create a new post in this board. I tried with both firefox and IE and the result is exactly the same. Is there a workaround ?
Message 12 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 13 of 22
thomas.channell
Could anyone point me in the direction of being able to achieve the above but for results for bars? I.E. forces and moments in a bar? I have had a look at changing the "IRobotFeResultType" but can't find an alternative.
Message 14 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @thomas.channell
Here is example for bars
Dim SelBar As RobotSelection
Set SelBar = RobApp.Project.Structure.Selections.Create(I_OT_BAR)
SelBar.AddText ("1")
SelCas.AddText ("1")
RobResQueryParams.Selection.Set I_OT_BAR, SelBar
RobResQueryParams.SetParam I_RPT_BAR_ELEMENT_DIV_COUNT, 11
RobResQueryParams.ResultIds.SetSize (6)
RobResQueryParams.ResultIds.Set 1, I_EVT_FORCE_BAR_FX
RobResQueryParams.ResultIds.Set 2, I_EVT_FORCE_BAR_FY
RobResQueryParams.ResultIds.Set 3, I_EVT_FORCE_BAR_FZ
RobResQueryParams.ResultIds.Set 4, I_EVT_FORCE_BAR_MX
RobResQueryParams.ResultIds.Set 5, I_EVT_FORCE_BAR_MY
RobResQueryParams.ResultIds.Set 6, I_EVT_FORCE_BAR_MZ
Dim v As Double
Dim max As Double
Dim min As Double
max = 0
min = 0
Do
Dim ok As Boolean
While ok
v = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(5))
Wend
End Sub
Rafal Gaweda
Message 15 of 22
thomas.channell
I am working in C# and am trying to instantiate the class below like:
RobotResultRowSet RobResRowSet = new RobotResultRowSet();
... but I then get the following error?
System.Runtime.InteropServices.COMException: 'Retrieving the COM class factory for component with CLSID {F335E413-5241-418C-9421-A4D1B545F923} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).'
Any ideas?
Message 16 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @thomas.channell
It must be 64 bit application \ exe as a result
Queryparams is only 64 bit.
Rafal Gaweda
Message 17 of 22
thomas.channell
Thanks for this :).
If we are running a 32 bit application/.exe, how much depreciation in speed would we expect.
Currently performing any interaction seems to lag a bit, hence the question.
Message 18 of 22
thomas.channell
Also, further to this, if there are any other methods of getting the results data out of Robot other than this method above and the method below?
RobotBarForceData forceData = robApp.Project.Structure.Results.Bars.Forces.Value(Convert.ToInt16(member.id), caseNumber, Point);
Message 19 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @thomas.channell
It depends on model size and amount of results. I can say,  in general, "significant" difference.
Rafal Gaweda
Message 20 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @thomas.channell
The above line in faster way, especially if you will use BarForceServer.Value(...)   in the loop:
Dim BarForceServer As RobotBarForceServer
Set BarForceServer = RobApp.Project.Structure.Results.Bars.Forces
Dim BFD As RobotBarForceData
For i = 1 To BarCol.Count Set BFD = BarForceServer.Value(....)
Next i
You will find other servers in Robot API
Methods depend on your choice. You can use also:
RobApp.Project.Structure.Results.Extremes....
Rafal Gaweda
