(API) Speed up API (Extract results)
alfredmx
Message 1 of 22
alfredmx
I need to extract panel node results from multiple model files.
I'm using the following code to extract results:
Dim robotapp As IRobotApplication
robotapp = New RobotApplication
For i = 1 To grid1.Rows.Count - 2
robotapp.Project.Open(vecrutafile(i - 1))
robotapp.Project.Preferences.Units.Refresh()
Dim filename As String
filename = "\" & grid1(i, 1) & "_" & txtfile2pan.Text & ".csv"
Dim objWriter As New IO.StreamWriter(savepath & filename)
Dim RSelection As RobotSelection
RSelection = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_PANEL)
RSelection.FromText(elem)
Dim panelcoll As RobotObjObjectCollection
panelcoll = robotapp.Project.Structure.Objects.GetMany(RSelection)
Dim FileLines As String
FileLines = ""
FileLines = "Panel,Node,Case,UXX (cm),UYY (cm),WNorm. (cm),RXX (Deg),RYY (Deg)" & vbCrLf
For j = 1 To panelcoll.Count
Dim obj As IRobotObjObject
obj = panelcoll.Get(j)
Dim panelnum As Long
panelnum = obj.Number
Dim nodes As String
Dim nodesel As RobotSelection
Dim nodecoll As RobotNodeCollection
nodes = obj.Nodes
nodesel = robotapp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_NODE)
nodesel.FromText(nodes)
nodecoll = robotapp.Project.Structure.Nodes.GetMany(nodesel)
Dim FEparams As New RobotFeResultParams
If combolayer.SelectedIndex = 0 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_UPPER
ElseIf combolayer.SelectedIndex = 1 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_MIDDLE
ElseIf combolayer.SelectedIndex = 2 Then
FEparams.Layer = IRobotFeLayerType.I_FLT_LOWER
Else
FEparams.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_UNDEFINED, 0, 0, 0)
For k = 1 To nodecoll.Count
Dim node As IRobotNode
node = nodecoll.Get(k)
Dim nodenum As Long
nodenum = node.Number
FEparams.Node = node.Number
FEparams.Case = caso
Dim FEresults As RobotFeResultDetailed
FEresults = robotapp.Project.Structure.Results.FiniteElems.Detailed(FEparams)
FileLines = FileLines & " " & panelnum & ", " & nodenum & ", " & caso & ","
FileLines = FileLines & Format(FEresults.UXX * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.UYY * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.WNorm * 100, "0.000") & ","
FileLines = FileLines & Format(FEresults.RXX * (180 / Math.PI), "0.000") & ","
FileLines = FileLines & Format(FEresults.RYY * (180 / Math.PI), "0.000") & vbCrLf
Next
Next
objWriter.Write(FileLines)
objWriter.Close()
robotapp.Project.Close()
 Next
robotapp.Quit(IRobotQuitOption.I_QO_DISCARD_CHANGES)
The problem is that extracting results for each model is taking up to 8min (larger models with aprox 300 panels and 80 nodes per panel), and total number of models is around 80.
Is there any way to speed up the process?
Replies (21)
Message 21 of 22
Hello Rafal,
I've tried to run the code you posted but I have some problems with it.
it seems there is some problem with RobResRowSet because excels returns me the next error
Object variable not settled down
Any Idea??
Thanks!
Message 22 of 22
marcinrakus
Make sure, You fulfilled all requirements that were listed in previous posts (registration, 64 bits (Excel has to be 64 bits as well), administrator rights, and so on).
Sometimes there has to be a 'Set' command added on excel, or some other syntax error (like brackets or something), but I this this is not a case.
You may also check different selection, different parameters of result query.
If that fails attach excel file and rtd example.
Marcin
