Problem with seismic analysis results
Message 1 of 8
Hi everyone,
I have the following problem: when I carry out seismic analysis with the parameters of the attached pic1, including live loads for Mass Conversion, I get the following awkward result (pic2) in the reaction table. When I exclude live loads from Mass Conversion, results seem normal. Has anyone meet the same problem?
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 3 of 8
Dear Rafal,
the file can be downloaded from the following link:
http://www.4shared.com/rar/qC2bkTCcba/Structure_-_v85p.html
during analysis you will see that a node has instability type 3. I have tried to solve the instability problem several times but always another node with instability is obtained. Is the instability problem relevant to the above prescribed problem? As you can see in the model are several user defined columns. Are columns-beams-slab properly connected in order to have rigid connections?
Thank you in advance.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Workaround:
either do not use eccentricities in Modal or delete case 14 from Loads to Mass Conversion list
Rafal Gaweda
Message 5 of 8
Dear Rafal thank for your answer but it seems that excluding lc 14 from load conversion list hasn't solved the problem (I get exactly the same picture in reaction table - use of Robot 2015). Additionally, ec8 asks for eccentricities to be taken into account, so I think it is right to perform four seismic analysis. Is there another way to achieve solution to the problem ?
Ioannis Verroios
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
File with results (no case 14 converted) : http://we.tl/sGWfU1vaYA
Rafal Gaweda
Message 7 of 8
Hi Rafal,
sorry for my late response. I saw the file you have sent me. I suppose that the problem was the solver because I tried to include lc14 and it seems to work. So, thanks a lot for your vital help. I have another question for the same file. Why the the total masses in the three directions UX-UY-UZ are not the same (see attached pic)?
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
The difference is ~0,15% so I think it is not worth to worry about it
Rafal Gaweda
