Message 1 of 14
Hi everyone,
I want screen captures for MXX,MYY and so on (sectional forces and moments) for the structure that I have. I want to just save these screen captures in jpeg format in a folder so that I can use them later.
I have written the following code:
IRobotView3 mavuerobot = Robapp.Project.ViewMngr.GetView(1) as IRobotView3;
mavuerobot.Selection.Get(IRobotObjectType.I_OT_CASE).FromText("1");
mavuerobot.Redraw(1);
mavuerobot.Projection = IRobotViewProjection.I_VP_3DXYZ;
mavuerobot.ParamsFeMap.CurrentResult = IRobotViewFeMapResultType.I_VFMRT_DETAILED_MOMENT_XX;
mavuerobot.Visible = 1;
Robapp.Project.ViewMngr.Refresh();
RobotViewScreenCaptureParams ScPar = Robapp.CmpntFactory.Create(IRobotComponentType.I_CT_VIEW_SCREEN_CAPTURE_PARAMS);
ScPar.Name = "First capture";
ScPar.UpdateType =IRobotViewScreenCaptureUpdateType.I_SCUT_CURRENT_VIEW;
ScPar.Resolution =IRobotViewScreenCaptureResolution.I_VSCR_4096;
mavuerobot.MakeScreenCapture(ScPar);
Could you please help me as to how I should save the screen capture in .jpeg now? And I am correctly capturing the screen capture for panel MXX through the above code?
Replies (13)
Message 2 of 14
Hi @Rafal.Gaweda,
I did the same. I copied the screen capture on to the clipboard and tried to paste it in Excel. It doesn't work. The screen capture is in what format? I am unable to get that.
if (Clipboard.GetDataObject() != null)
IDataObject data = Clipboard.GetDataObject();
if (data.GetDataPresent(DataFormats.Bitmap))
Image image = (Image)data.GetData(DataFormats.Bitmap, true);
image.Save("image.bmp", System.Drawing.Imaging.ImageFormat.Bmp);
image.Save("image.jpg", System.Drawing.Imaging.ImageFormat.Jpeg);
image.Save("image.gif", System.Drawing.Imaging.ImageFormat.Gif);
else
MessageBox.Show("The Data In Clipboard is not as image format");
else
MessageBox.Show("The Clipboard was empty");
When I try the above snippet of code, it shows that the data in clipboard is not in image format.
I am trying to paste the contents of clipboard like this:
xlWorkbook.Sheets["Results"].Range("B" + D * 45).Paste();
But this doesn't work. It throws an error. I somehow feel it is due to the format of the clipboard contents.
I have been able to do it in VBA though.
Call InsPicFromClipbrd("B" & M * 45, TitleName)
This works great.
Could you please help me resolve this for my C# code?
Message 3 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
My example VBA code works:
Sub screen_capture()
Set robapp = New RobotApplication
Dim mavueRobot As IRobotView3
Set mavueRobot = robapp.Project.ViewMngr.GetView(1)
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "capture"
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
ScPar.Resolution = I_VSCR_4096
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
mavueRobot.MakeScreenCapture ScPar
ActiveSheet.Range("A1").Select
ActiveSheet.Paste
End Sub
Rafal Gaweda
Message 4 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
HI @Anonymous
BTW, there is no way to save screen capture to jpeg, only to rtf
Rafal Gaweda
Message 5 of 14
Thank you for your response. But this doesn't seem to work, unfortunately
Message 6 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Rafal Gaweda
Message 7 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
C# example:
using System.Runtime.InteropServices;
using Excel = Microsoft.Office.Interop.Excel;
        private void button1_Click(object sender, EventArgs e)
            RobotOM.IRobotApplication RobApp = new RobotOM.RobotApplication();
            IRobotView3 myviewRobot ;
            myviewRobot = (IRobotView3) RobApp.Project.ViewMngr.GetView(1);
            RobotViewScreenCaptureParams ScPar;
            ScPar = RobApp.CmpntFactory.Create(IRobotComponentType.I_CT_VIEW_SCREEN_CAPTURE_PARAMS);
            ScPar.UpdateType = IRobotViewScreenCaptureUpdateType.I_SCUT_COPY_TO_CLIPBOARD;
ScPar.Resolution = IRobotViewScreenCaptureResolution.I_VSCR_4096; myviewRobot.MakeScreenCapture(ScPar); Excel.Application xlApp; Excel.Workbook xlWorkBook; Excel.Worksheet xlWorkSheet; object misValue = System.Reflection.Missing.Value; xlApp = new Excel.Application(); xlApp.Visible = true; xlWorkBook = xlApp.Workbooks.Add(misValue); xlWorkSheet = (Excel.Worksheet)xlWorkBook.Sheets["Sheet1"]; xlWorkSheet.Name = "Screen Capture"; xlWorkSheet.Range["A1"].Select(); xlWorkSheet.Paste(); }
Rafal Gaweda
Message 8 of 14
Hi @Rafal.Gaweda,
Thank you for your response. This works great.
I have one more question for you. How do I get a decent zoomed in screenshot? Right now what I am getting is a horribly out of scale picture. I have tried to use this:
double V_left = 0; double V_top = 0; double V_bottom = 0; double V_right = 0;
RView.GetZoom(out V_left, out V_top, out V_right, out V_bottom);
RView.SetZoom(V_left, V_top, V_right, V_bottom);
robotApplication.Project.ViewMngr.Refresh();
RobotViewScreenCaptureParams SSParams = robotApplication.CmpntFactory.Create(IRobotComponentType.I_CT_VIEW_SCREEN_CAPTURE_PARAMS);
string TitleName = "";
SSParams.Name = Options[n, 2].ToString() + "-" + Options[n, envelope];
SSParams.ScaleAutomatic = true;
TitleName = SSParams.Name;
SSParams.UpdateType = IRobotViewScreenCaptureUpdateType.I_SCUT_CURRENT_VIEW;
SSParams.Resolution = IRobotViewScreenCaptureResolution.I_VSCR_4096;
SSParams.UpdateType = IRobotViewScreenCaptureUpdateType.I_SCUT_COPY_TO_CLIPBOARD;
RobotMapView.MakeScreenCapture(SSParams);
Message 9 of 14
This is the image I am getting. I have attached the Excel file containing the screenshot as obtained by the API
Message 11 of 14
Hi @Rafal.Gaweda,
I tried the code in Post 25. No luck there. Badly distorted images. Only part of the panel available in images. Over-zoomed, etc. Could you please help? Any more suggestions?
Message 12 of 14
hi @Rafal.Gaweda,
And the screenshot picture is huge too. I meant the dimensions. Any way to resolve that?
Message 14 of 14
Hi @Rafal.Gaweda,
Thank you for your reply.
I reduced the zooming factor to 1. Some images are of okay resolution and clarity (the ones at the bottom the Results sheet), whereas some are of partial panels and bad quality (stretched; the ones at the top of the same sheet). Could you please take a look?
