Incorrect reults in reinforcement calculations
I'm getting unusual moment and shear diagrams when I run the reinforcement calculations.
When I view the results I get moment diagrams which look sensible.
Screenshots below to explain. Help would be appreciated.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the model?
Artur Kosakowski
Pawel.Pulak
Autodesk Support
Autodesk Support
Solved outside of the forum.
The reason was in using the combinations containing moving loads. It was necessary to convert them to simple combinations.
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
