load distribute generation on incline cladding like roof.
Hi Autodesk support team,
How can I generate load distribution on incline cladding panel. I also attached my file for your reference. Thank you very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The claddings have to be (perfectly) flat. If they aren't you may consider generation of meshes having material with small E as well as small thickness assigned to them.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
