API - Panel Cuts
API - Panel Cuts
API - Panel Cuts
Guys, can you tell why this code is not working ?
And what is the significance of row ((1))  ?
Set pan_cut = robapp.Project.Structure.Results.FiniteElems.PanelCuts.Create
RView.Projection = I_VP_XY_3D
RView.ParamsPanelCut.CurrentResult = Cells(11, 2).Value
RView.ParamsPanelCut.IntegralValue = True
RView.ParamsPanelCut.Smoothing = I_VFMST_NO_SMOOTHING
RView.ParamsPanelCut.Layer = I_VFMLT_MIDDLE                                           ((1))
RView.ParamsPanelCut.Descritpions = I_VDDT_TEXT
RView.ParamsPanelCut.Filling = I_VDFT_FENCE
RView.ParamsFeMap.CurrentResult = Cells(11, 2).Value
RView.ParamsPanelCut.Position = I_VDPT_IN_PLANE
RView.Redraw 1
pan_cut.DefinitionType = I_PCDT_LIMITED_PLANE
pan_cut.Point1.Set x1, y1, z1
pan_cut.Point2.Set x2, y2, z2
robapp.Project.Structure.Results.FiniteElems.PanelCuts.Store pan_cut, npcname1
pan_cut.Active = True
pan_cut.Color = 3
RView.Redraw 1
marcinrakus
There is a problem with API concerning panel cuts.
If You have problem with displaying the cut there is some trick, that may help You:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-api-panel-cut-parameters/td-p/7...
And as regards position on layer - the difference should be observed when analysis of stresses, which are dependent on layer.
Marcin
jmmarin
Dear @Anonymous,
I am trying to do something like your code. Could you kindly send to me the rest of the code?. I have some doubts with the declaration of "Rview" in your code.
Thank you in advance. Regareds.
Hi
For creating panel cuts you can use this code. Please share if any modifications can be done.
Sub CommandButton1_Click()
Dim robapp As RobotApplication
Set robapp = New RobotApplication
Dim x1 As Double
Dim x2 As Double
Dim y1 As Double
Dim y2 As Double
Dim z1 As Double
Dim z2 As Double
Dim n As Integer
n = Cells(8, 2).Value
Cells(1, 1) = "PANEL CUT API"
x1 = Cells(5, 2).Value
y1 = Cells(6, 2).Value
z1 = Cells(7, 2).Value
x2 = Cells(5, 3).Value
y2 = Cells(6, 3).Value
z2 = Cells(7, 3).Value
Dim npcname1 As String
npcname1 = Cells(4, 6)
Dim RView As IRobotView3
Set RView = robapp.Project.ViewMngr.GetView(n)
RView.ParamsFeMap.Direction = I_VFMLST_CARTESIAN_ALONG_X
Dim pan_cut As RobotPanelCut
RView.Redraw 1
pan_cut.Color = 3
RView.Redraw 1
Set robapp = Nothing
End Sub
Regards
Saurav
jmmarin
Thank you!.
In my opinion your approach is good so nothing to improve!. It does what required. As explained in the other reply, it seems that some parameters can not be controlled by API, but if the intention is to create parametric sections, this code run well.
Regards!.
jmmarin
Hi @Anonymous
do you get to change the color of the section by using the following instruction?
pan_cut.Color = 3
I can not change the colour, it is alwayis displayed in black...
Regards.
Jorge
