Robot API - panel cut - Parameters
hvdsidf
hvdsidf
Bonjour,
Could you please show me the code VBA to show the parameters below for the panel cut:
     1. Diagramme Description = "texte"
     2. Diagramme name = "un check"
     3. Fill type = "Uniform"
     4. show the window "panel cut" as below by API.
I've tried to find them in the manual "Robot API.pdf", I know that we can do it with API, but I don't know.
Thanks in advance,
HUA Van Dong
SIDF
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @hvdsidf
See below
It should be always displayed
See below
Using Robot API you can open graphical windows and tables , not dialog windows.
Unfortunately due to API issue these lines do not work
vue.ParamsPanelCut.Position = I_VDPT_IN_PLANE ' I_VDPT_NORMAL
vue.ParamsPanelCut.Descritpions = I_VDDT_LABELS 'I_VDDT_TEXT
vue.ParamsPanelCut.Filling = I_VDFT_FILLED
The workaround :
flag 1 - labels (0 for nothing)
flag 2 - text (0 for nothing)
flag 256 - inplane ( 0 for normal)
flag 512 - filled ( 0 for fence)
so
to display :
Labels + inplane+ filled :
vue.SetVisibilityStatus I_VVST_MAPS_DEFORMATION, 1 + 256 + 512
to display :
text + normal + filled :
vue.SetVisibilityStatus I_VVST_MAPS_DEFORMATION, 2 + 0 + 512
Rafal Gaweda
