(API) Finite element results for CQC combinations
alexanderziotopoulos5224
Message 1 of 13
in the forum there is an example where you can get finite element results via API using an excell file and VBA.
Using this file when exporting results from a model containing earthquake analysis results it seems that only the results from mode 1 are exported for the excitation directions (X Y Z) and not from the CQC combination of the modes.
Is there a possibility to specify that the CQC combination of the modes is to be exported when having earthquake analysis results.
Replies (12)
Message 2 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
Sure it can be done
Take a look at attached macro
Rafal Gaweda
Message 3 of 13
Thanks Rafal.
Message 4 of 13
alexander.silvaGA9XG
Hi mr. Rafal,
Can you tell me if it possible to get the complex result (top and bottom reinforcement) at the FE nodes and/or from a section cut?
Thanks.
Message 5 of 13
hi @alexander.silvaGA9XG
You can add a polyline on your panel before meshing and extract the results at the corresponding nodes.
Best Regards
See also : Panel cuts in panels in tablature form?
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 6 of 13
miguel_paulinoY2Y8C
Observer
Observer
"I'm struggling to get there on my own. Would you happen to have an example, maybe in Python or a similar language, that you could share?"
Message 7 of 13
hi @miguel_paulinoY2Y8C
Have you tried using an AI tool or a code conversion website, such as ChatGPT, deepseek, GitHub Copilot, or code converters like Telerik Code Converter or CodeTranslator.com?
Why not use @Rafal.Gaweda's Excel app if you're not familiar with coding?
Best Regards
Message 8 of 13
Just translating code into another language without adding anything new isn’t very helpful for the forum. Do you have any extra features or improvements in mind?
Message 9 of 13
miguel_paulinoY2Y8C
Observer
Observer
Dear Stephane,
Our goal is to analyze the redistribution of complex forces in reinforcement elements perpendicular to a defined section ("cut").
If there is a way to extract both bottom and top reinforcement values and their positions in a format that would allow for graphical plotting, that would be greatly appreciated.
Thank you in advance for your support.
Message 10 of 13
reinforcement => not implemented   (API) Geting Required Reinforcement on panels
For tabulated cutting results, refer to the values at the nearest nodes.
Message 11 of 13
Mr. Stephane,
What about the complex forces, is implemented by API?
Message 12 of 13
as explained first follow the code provided by @Rafal.Gaweda, here is my test ↓
static string GetFormatedValues(RobotFeResultReinforcement r)
    => string.Concat(new[] { r.AX_BOTTOM, r.AX_TOP, r.AY_BOTTOM, r.AY_TOP }.Select(v => $"{v * 10000,10:F2}"));
static void PrintPanelReinforcements(string panels) {
    RobotApplication RobApp = new(); int wl = RobApp.Preferences.GetLanguage(I_L_WORK);
    RobotStructure structure = RobApp.Project.Structure;
    var pSel = structure.Selections.Create(I_OT_PANEL); pSel.FromText(panels);
    foreach (int p in pSel.AsArray(wl))
        foreach (int n in ((RobotObjObject)structure.Objects.Get(p)).Nodes.AsArray(wl))
            WriteLine($"{$"{p} / {n}",-10}{GetFormatedValues(structure.Results.FiniteElems.Reinforcement(p, n))}");
Message 13 of 13
For once, here’s a C# interpretation of the original VBA code.
Compared to Excel, displaying results in the console allows you to divide the execution time by 2.
You can save another 30-50% by using classes, and even more if you reduce the output to a simple data table for plotting.
public static void PrintCQCResultsForForum(string panels, string cases) {
    if (string.IsNullOrEmpty(panels) || string.IsNullOrEmpty(cases)) return;
    if (RobApp.Visible != -1 || RobApp.Project.IsActive != -1 ||
        !new[] { I_PT_PLATE, I_PT_SHELL, I_PT_BUILDING }.Contains(RobApp.Project.Type) ||
        RobApp.Project.Structure.Results.Available != -1) return;
    RobotStructure Structure = RobApp.Project.Structure;
    RobotSelectionFactory Selections = Structure.Selections;
    RobotSelection ps = Selections.Create(I_OT_PANEL); ps.FromText(panels); if (ps.Count == 0) return;
    RobotSelection cs = Selections.Create(I_OT_CASE);  cs.FromText(cases);  if (cs.Count == 0) return;
    int wl = RobApp.Preferences.GetLanguage(I_L_WORK); var symbols = new[] { "+", "-" };
    var feStrings = ps.ToArray(wl).Select(p => ((RobotObjObject)Structure.Objects.Get(p)).FiniteElems);
    int[] FEsNumbers = string.Join(" ", feStrings).ToArray(wl),
         CaseNumbers = cs.ToArray(wl);
    RobotFeResultServer FeRS = Structure.Results.FiniteElems;
    RobotFeResultParams FePrms = new() { Layer = IRobotFeLayerType.I_FLT_MIDDLE };
    FePrms.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_CARTESIAN, 1, 0, 0);
    static string GetFormatedValues(IRobotFeResultComplex c, IRobotFeResultDetailed d)
        => string.Concat(new[] { d.QXX, d.QYY, c.MXX_TOP, c.MXX_BOTTOM, c.MYY_TOP, c.MYY_BOTTOM }.Select(v => $"{v,15:F2}"));
    void Print(string name, RobotFeResultParams Params) => WriteLine($"{name,-15}{GetFormatedValues(FeRS.Complex(Params), FeRS.Detailed(Params))}");
    string main = "FE / Case";
    string[] headers = ["QXX", "QYY", "MXX_TOP", "MXX_BOTTOM", "MYY_TOP", "MYY_BOTTOM"];
    WriteLine("Project: " + RobApp.Project.Name);
    WriteLine(main.PadRight(15) + string.Concat(headers.Select(h => h.PadLeft(15))));
    foreach (int FeNo in FEsNumbers) { FePrms.Element = FeNo;
        foreach (int CasNo in CaseNumbers) { FePrms.Case = CasNo;
            IRobotCase cas = Structure.Cases.Get(CasNo); if (symbols.Any(cas.Name.Contains)) continue;
            switch (cas.Type) {
                case IRobotCaseType.I_CT_SIMPLE: case IRobotCaseType.I_CT_COMBINATION:
                    if (cas.AnalizeType == IRobotCaseAnalizeType.I_CAT_DYNAMIC_SEISMIC) FePrms.ModeCmb = IRobotModeCombinationType.I_MCT_CQC;
                    Print($"{FeNo} / {CasNo}", FePrms); break;
                case IRobotCaseType.I_CT_MOBILE: FePrms.Case = CasNo;
                    IRobotMobileCaseComponentMngr Components = ((IRobotMobileCase)cas).Components;
                    for (int k = 1; k <= Components.Count; k++) {
                        FePrms.CaseCmpnt = Components.Get(k).Point; Print($"{FeNo} / {CasNo} / {FePrms.CaseCmpnt}", FePrms);
                    break;
see also parse a Robot list string into an array of integers (offline)
Best Regards
