Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Instability and no convergence of nonlinear problem
hogerc
Observer Observer
hogerc
Observer
Observer
Hi, I have a model of a tower frame with tension only web members and stay cables.  I am receiving error messages of no convergence of a nonlinear problem and I have instability in two nodes I cannot troubleshoot.
Please help!  My model is attached, thank you!
Rafacascudo
Zip it before attaching
Rafael Medeiros
hogerc
Observer
Observer
Thanks for looking at this, please see zip file attached.
Rafacascudo
no need to assign those diagonals as tension only bars. Change them back to regular bars and the model will converge with no instabilities
Another option is to keep those diagonals as truss bars ,but resisting tension and compression . But also change the releases pinned-fixed and fixed-pinned to be blocked on the RX direction(torsion  ,because this is causing the instability type 2 which cannot be ignored
Rafael Medeiros
