hi @miguel_paulinoY2Y8C
For once, here’s a C# interpretation of the original VBA code.
Compared to Excel, displaying results in the console allows you to divide the execution time by 2.
You can save another 30-50% by using classes, and even more if you reduce the output to a simple data table for plotting.
public static void PrintCQCResultsForForum(string panels, string cases) {
if (string.IsNullOrEmpty(panels) || string.IsNullOrEmpty(cases)) return;
RobotApplication RobApp = new();
if (RobApp.Visible != -1 || RobApp.Project.IsActive != -1 ||
!new[] { I_PT_PLATE, I_PT_SHELL, I_PT_BUILDING }.Contains(RobApp.Project.Type) ||
RobApp.Project.Structure.Results.Available != -1) return;
RobotStructure Structure = RobApp.Project.Structure;
RobotSelectionFactory Selections = Structure.Selections;
RobotSelection ps = Selections.Create(I_OT_PANEL); ps.FromText(panels); if (ps.Count == 0) return;
RobotSelection cs = Selections.Create(I_OT_CASE); cs.FromText(cases); if (cs.Count == 0) return;
int wl = RobApp.Preferences.GetLanguage(I_L_WORK); var symbols = new[] { "+", "-" };
var feStrings = ps.ToArray(wl).Select(p => ((RobotObjObject)Structure.Objects.Get(p)).FiniteElems);
int[] FEsNumbers = string.Join(" ", feStrings).ToArray(wl),
CaseNumbers = cs.ToArray(wl);
RobotFeResultServer FeRS = Structure.Results.FiniteElems;
RobotFeResultParams FePrms = new() { Layer = IRobotFeLayerType.I_FLT_MIDDLE };
FePrms.SetDirX(IRobotObjLocalXDirDefinitionType.I_OLXDDT_CARTESIAN, 1, 0, 0);
static string GetFormatedValues(IRobotFeResultComplex c, IRobotFeResultDetailed d)
=> string.Concat(new[] { d.QXX, d.QYY, c.MXX_TOP, c.MXX_BOTTOM, c.MYY_TOP, c.MYY_BOTTOM }.Select(v => $"{v,15:F2}"));
void Print(string name, RobotFeResultParams Params) => WriteLine($"{name,-15}{GetFormatedValues(FeRS.Complex(Params), FeRS.Detailed(Params))}");
string main = "FE / Case";
string[] headers = ["QXX", "QYY", "MXX_TOP", "MXX_BOTTOM", "MYY_TOP", "MYY_BOTTOM"];
WriteLine("Project: " + RobApp.Project.Name);
WriteLine(main.PadRight(15) + string.Concat(headers.Select(h => h.PadLeft(15))));
foreach (int FeNo in FEsNumbers) { FePrms.Element = FeNo;
foreach (int CasNo in CaseNumbers) { FePrms.Case = CasNo;
IRobotCase cas = Structure.Cases.Get(CasNo); if (symbols.Any(cas.Name.Contains)) continue;
switch (cas.Type) {
case IRobotCaseType.I_CT_SIMPLE: case IRobotCaseType.I_CT_COMBINATION:
if (cas.AnalizeType == IRobotCaseAnalizeType.I_CAT_DYNAMIC_SEISMIC) FePrms.ModeCmb = IRobotModeCombinationType.I_MCT_CQC;
Print($"{FeNo} / {CasNo}", FePrms); break;
case IRobotCaseType.I_CT_MOBILE: FePrms.Case = CasNo;
IRobotMobileCaseComponentMngr Components = ((IRobotMobileCase)cas).Components;
for (int k = 1; k <= Components.Count; k++) {
FePrms.CaseCmpnt = Components.Get(k).Point; Print($"{FeNo} / {CasNo} / {FePrms.CaseCmpnt}", FePrms);
break;
see also parse a Robot list string into an array of integers (offline)
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
