Panel cuts in panels in tablature form?
skellyRSA2023
skellyRSA2023
When looking at the results for panels i.e. reduced results or panels and look up the forces for the panel in question. Reduced results for panels give me a the option of showing the panel cut length and panel height. However this as generally as per the overall vertical and horizontal cuts through the panel as per the cut tab and cut position tab/boxes. However if I want to take a specific panel cut to a point I would go to results/panel cuts and take a cut a specific location and view the reduced forces for this area, my question is there a way of getting these specific reduced results for specific cuts that I make in the panels in the model into a table format? rather than having to make the cut and then jot it down?
Rgds,
Simon.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
Currently there is no option for having user defined cuts results in the tabular form in Robot.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
