Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wood Truss Family
3 REPLIES 3
10367 Views, 3 Replies
Wood Truss Family
Does anyone know if there is a parametric wood truss family for Revit 2017?  Do I need to draw the trusses?
I am a newbie to Revit Structure so any help is appreciated!!
Angela
3 REPLIES 3
dzanta
There are lots of truss families by default in Revit...just start the Truss command and then load them from the Imperial Library.  As for the material being wood, I assume this is for a Residential project.  If so, start with a residential template file and then use the truss command.  Once the truss you want is loaded, use it.  Then go to its properties to specify the type of member you want for the webs, top and bottom chords.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Rafal.Gaweda
in reply to: Rafal.Gaweda
Thank you so much for the links - I will have a look at those 😄
