Hi Guys, I have a question about the W - Nominal Weight in Properties Edit.
Is the default kg/m?
For instance, my current parameter is for IPE200AA is 0.176520 as a default, and the list I have for the steel weight properties is,18 kg/m
Designation | h | b | tw | tf | r1 | m |
| mm | mm | mm | mm | mm | kg/m |
IPE-AA 200 | 196.4 | 100 | 4.5 | 6.7 | 12 | 18 |
I am confused.
