Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel beam properties
1 REPLY 1
429 Views, 1 Reply
Hi Guys, I have a question about the W - Nominal Weight in Properties Edit.
Is the default kg/m?
For instance, my current parameter is for IPE200AA is 0.176520 as a default, and the list I have for the steel weight properties is,18 kg/m
Designationtw tf r1m
 mm mm mm mm mmkg/m
IPE-AA 200196.41004.56.71218
I am confused.
 mm mm mm mm mmkg/m
I am confused.
1 REPLY 1
aleksei.tkachenko
aleksei.tkachenko
Hello
Default is Kilograms force per meter and in your case it is Kilonewtons per meter.
Hello
