Does anyone know if there is a parametric wood truss family for Revit 2017? Do I need to draw the trusses?
I am a newbie to Revit Structure so any help is appreciated!!
Angela
Angela
Solved by Rafal.Gaweda. Go to Solution.
There are lots of truss families by default in Revit...just start the Truss command and then load them from the Imperial Library. As for the material being wood, I assume this is for a Residential project. If so, start with a residential template file and then use the truss command. Once the truss you want is loaded, use it. Then go to its properties to specify the type of member you want for the webs, top and bottom chords.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi
See also:
https://bimobject.com/en-us?origin=seek
https://www.revitcity.com/downloads.php?action=viewmf04&mf04_l1_id=7
Hi
See also:
Thank you so much for the links - I will have a look at those 😄
