wood steel connections
Martin.EckartJLZX3
Message 1 of 11
Martin.EckartJLZX3
how can i make some connections like in the picture
wood steel connections?
Replies (10)
Message 2 of 11
Rob_Merriman
Hi @Martin.EckartJLZX3
You will need to build this as a custom connection using the contour tools, plates, bolts etc then put it all together
I have actually done a webinar on working with Timber in Advance Steel and built that connection, you will find it on this page
https://graitec.co.uk/cad-courses/training-tutorials-and-webinars/advance-steel-content-portal
Rob Merriman, AEC Technical Lead, Graitec
Message 3 of 11
Martin.EckartJLZX3
but i cant use bolt connections with wood beams + plates , only with steel beams + plates
is there another option?
Message 4 of 11
Rob_Merriman
I don't have my.computer on at the moment but I'm.usre you can bolt through a timber bean, how have you created your timber beams?
The other option is to model them using the Steel beam command changing the section size to a timber section then the material to timber
Message 5 of 11
Rob_Merriman
Appologies, i thought this question had been posted in the Advance Steel forum, there is no restriction in Advance Steel on connecting through timber elements.
In Revit the steel tools will only work on elements with the structural behaviour of steel, you could maybe change the behaviour of your timber beams so Revit thinks they are steel, although im sure this will then cause other issues
Message 6 of 11
PhilipLTnz
I've created new timber families which have the "Material for model behaviour" set to "steel" as we do lots of timber/steel structures.
Use Shear plates for a lot of my timber/steel connections works a dream.
Message 7 of 11
Martin.EckartJLZX3
can i have these families? 🙂
Message 8 of 11
PhilipLTnz
 Within your timber structure element (frames & Columns) change the highlighted field to steel.
I'm newish to revit and guess i'll get told off but the only way I have found to get revit to work with timber/steel connections.
Message 9 of 11
Martin.EckartJLZX3
doesnt work 😕
i also testet shear plates and bolts ..
Message 10 of 11
PhilipLTnz
This is in 2021 but also worked in 2020, have attached project of this alsoCapture2.JPG
Message 11 of 11
dali.jmal
Section Shape should also be : Undefined. Then it will work fine
