Hi @Martin.EckartJLZX3
Appologies, i thought this question had been posted in the Advance Steel forum, there is no restriction in Advance Steel on connecting through timber elements.
In Revit the steel tools will only work on elements with the structural behaviour of steel, you could maybe change the behaviour of your timber beams so Revit thinks they are steel, although im sure this will then cause other issues
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
