- Mute
- Permalink
- Report
Greetings
I have been working with the Wood framing Extension for the past moth and I found this great video from Autodesk that shows step by step on how to accomplish the work.
But I have a problem that I can not get around it.
I draw my Studs Walls 2x and go thru the whole process of doing wall, opening, sill, plate ect. Once I am done i save it click okay just to find out the all the framing generated by the "wood framing extension" is not centered in the Stud Wall I drew. The center of the framing that was generated in center in inside face of the Stud Wall.
I do not know if I am missing something and why is doing that. Some has ab idea why is behaving like this. Thanks in advance, your reply will be greatly appreciated.
PS. I can post a pic as soon as I get back to the office to give you a better idea if needed
Westrada
