Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wood Floor - Joists and beams
3 REPLIES 3
9569 Views, 3 Replies
How can I load a wood-joists-floor in Revit?
If so can I specify if the joists are supported by Bridging or Strapping?
3 REPLIES 3
Revit_Whisperer
You can load them either from the Insert tab, load a family, Structural Framing
or you can go to the Structure tab, Beam tool, Load a Family, Structural Framing.
I did a quick video
G:\_Blogs\_Video Tips\2017\Wood_Joist.swf
If you are wanting just a floor type that is listed as a Wood Joist Floor with the appropriate layers and thicknesses you can duplicate an existing floor type and create a new one.  Keep in mind this does not show the joists, it just shows the thicknesses of the layers in the floor structure.
MostafaElashmawy
This can be done using plugin by AGACAD.
Refer to below videos:
https://www.youtube.com/watch?v=o20rKwHf9Ws
https://www.youtube.com/watch?v=M9m3cXMW_iQ
Mostafa Elashmawy
Forma Design Contest
