Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
5-Oct-22 |
Creation of part on framework in a Revit model not possible because the "Invalid shape found in original. Parts could not be created." message appears. |
Yes |
5-Oct-22 |
Is it recommended to change the height of the datum (reference point) during the design process in Revit? |
Change the height of the datum (reference point) during the design process in Revit |
No |
5-Oct-22 |
Freeze for a few minutes when selecting or moving elements from a specific Category in Revit. |
Freeze when selecting or moving elements from specific Category in Revit |
No |
5-Oct-22 |
Is it possible to automatically number elements in Revit? |
No |
5-Oct-22 |
Is it possible to import layers' names, colors, and thickness from the DWG file to Revit? |
How to import layers names, colors and thickness from DWG file to Revit |
No |
5-Oct-22 |
Users reported that Revit 2021 and Navisworks 2021 fail to display all elements in a specific IFC file, even though the same file opens without an issue in other IFC Viewers. |
Missing elements in IFC file when opening in Navisworks 2021 or Revit 2021 |
Yes |
5-Oct-22 |
Missing walls while analytical automation in Revit 2023 |
No |
5-Oct-22 |
Users reported that NWC exporter creates larger file sizes from Revit 2022 than from previous Revit versions. |
NWC exporter creates larger file size from Revit 2022 than from previous Revit versions |
Yes |
5-Oct-22 |
How to print a schedule to PDF without Title Sheet in Revit? |
No |
5-Oct-22 |
Users reported that railing posts are not extended to the last stair tread in Revit. |
Railing posts are not extended to the last stair tread in Revit |
Yes |
5-Oct-22 |
Rebar schedule placed on sheet is empty in Revit 2023 |
No |
5-Oct-22 |
Revit crashes when using third-party add-in Bimsync features. |
No |
5-Oct-22 |
How to split and resize a schedule in Revit? |
No |
7-Oct-22 |
Exporting a set of views to PDF takes a long time in Revit. |
No |
7-Oct-22 |
Warning "Line in Sketch is slightly off axis and may cause inaccuracies." appears when Project North is rotated in Revit. |
Warning about the “off-axis” elements appears when Project North is rotated in Revit |
No |
8-Oct-22 |
"Missing data: Categories, Type or Instance" when using Parameter Service on ACC platform |
No |
10-Oct-22 |
Users reported that Revit crashes regularly for specific projects while syncing to central. The CER report will be sent. |
Crash at Save to Central stage while synchronizing to central in Revit |
Yes |
10-Oct-22 |
Is it possible to use the Revit Server workflow with Revit adding cryptographic information protection on a public network? |
Does the Revit Server workflow support cryptographic information protection? |
No |
10-Oct-22 |
Is the network traffic between Revit client machines and Revit Server encrypted? |
Network traffic encryption between Revit client machines and Revit Server |
No |
10-Oct-22 |
Users reported that rebar constraints are not respected for all rebars in the layout in Revit. |
Rebar constraints are not working for all elements from rebar set in Revit |
Yes |
10-Oct-22 |
Unable to use a 600 mm width, asymmetric bend in a Particular Project in Revit |
Yes |
11-Oct-22 |
Users reported that the "System.TypeLoadException[...]" message is displayed while attempting to launch Dynamo and Dynamo Player from Revit. Dynamo cannot be started. |
"System.TypeLoadException[...]" while attempting to launch Dynamo and Dynamo Player from Revit |
Yes |
11-Oct-22 |
Is a geographical coordinates collaboration possible between Formit and Revit? |
Geographical coordinates collaboration between Formit and Revit |
No |
11-Oct-22 |
How to get the location (insertion point) of the doors placed in facades in Dynamo for Revit? |
How to get the position of the doors placed in facades in Dynamo for Revit |
No |
11-Oct-22 |
How to sort elements by their location, for example, by level or X, Y coordinates in Dynamo for Revit? |
No |
11-Oct-22 |
Revit cannot be installed on a newly installed and updated Windows 10. |
No |
