Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Weekly New Knowledge Articles by Support team | Oct 19th - 25th, 2022
0 REPLIES 0
Message 1 of 1
lim.wendy
70 Views, 0 Replies
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
24-Oct-22
Users reported that "This computer does not have enough memory to open" message is displayed when saving an upgraded Revit model.
"This computer does not have enough memory to save" message when saving an upgraded Revit model
Yes
24-Oct-22
How export to IFC coordinates with decimals from Revit
No
24-Oct-22
Insulation is not displayed when applied to Fabrication pattern CID 480 in Revit
No
21-Oct-22
"Hollow core slab does not support reinforcement" message appears when trying to reinforce the hollow slab with Precast features in Revit.
"Hollow core slab does not support reinforcement" warning appears in Revit
No
21-Oct-22
Background process :  Failed to calculate System Volumes or Modification calculation to steel members failed in Revit
Background process :  Failed to calculate System Volumes or Modification calculation to steel member...
No
21-Oct-22
How to model precast stair run with custom "teeth" at the beginning and at the end in Revit?
How to model stair with custom notches in Revit
No
21-Oct-22
Is it possible to import IFC model to certain phase in Revit?
No
21-Oct-22
Users reported that the volume of floors is incorrectly calculated when cutting them with voids in Revit
Wrong volume of floors when cutting them with voids in Revit
Yes
21-Oct-22
Disturbing additional line after importing Revit model in the host file
Disturbing additional line after linking Revit model in the host file
No
20-Oct-22
When printing from Revit to pdf, in the zone where an opening is place, is not always visible the color fill of the  pipein the PDF but yes in the Revit model.
The solid fill on pipes is not printed when a void is placed in Revit
Yes
19-Oct-22
Subregions defined on toposurface are not visible in Revit.
Subregions are not visible in Revit
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
0 REPLIES 0
Forma Design Contest
