Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
wall reveal
4 REPLIES 4
523 Views, 4 Replies
wall reveal
Hi there,
I have a question about wall reveals. When i use wall reveal or wall sweep, the profile dont fit well by windows with round edges. Any solutions?Schermopname (34).pngSchermopname (35).png
4 REPLIES 4
hmunsell
are you using Reveal to place siding? interesting....
A Reveal is basically a straight extrusion along a surface, it will stop or break where the line gets broken. You may be able to do a Model in Place component in the areas that are effected.
Howard Munsell
in reply to: hmunsell
I try diffrent methods but nothing works. How can I fix this on the best
way?
hmunsell
I made a in place model (extrusion) of the siding categorized as a Wall. then edited the opening of the window family to the outside extents of the trim. when you place the window it makes the opening. maybe not ideal, but it works :-).
Howard Munsell
It works but on some places i have windows that cant open so what do there?
Forma Design Contest
