Hi there,
I have a question about wall reveals. When i use wall reveal or wall sweep, the profile dont fit well by windows with round edges. Any solutions?
Solved by hmunsell. Go to Solution.
are you using Reveal to place siding? interesting....
A Reveal is basically a straight extrusion along a surface, it will stop or break where the line gets broken. You may be able to do a Model in Place component in the areas that are effected.
Howard Munsell
I made a in place model (extrusion) of the siding categorized as a Wall. then edited the opening of the window family to the outside extents of the trim. when you place the window it makes the opening. maybe not ideal, but it works :-).
Howard Munsell
