Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wall not going till SSL level.
2 REPLIES 2
shuaib009
308 Views, 2 Replies
Top of Wall is not going till structure slab level (SSL)
Getting stopped below the slab level. Though in properties I have chosen right parameters!
Kindly anyone let me know, How can I fix this problem?
2 REPLIES 2
EdwinG
in reply to: shuaib009
looks like the wall is attached to the floor, detach the wall should fix your problem.
ennujozlagam
check your if it constraint to base level and top level or constraint to the attach top/base of the floor slab and you need to detach top/base to the floor. thanks
Forma Design Contest
Technology Administrators
