Top of Wall is not going till structure slab level (SSL)
Getting stopped below the slab level. Though in properties I have chosen right parameters!
Kindly anyone let me know, How can I fix this problem?
Solved by ennujozlagam. Go to Solution.
check your if it constraint to base level and top level or constraint to the attach top/base of the floor slab and you need to detach top/base to the floor. thanks
