I have two different wall types, one goes up by 200mm, the other goes up to the roof as I've shown in section view below.
I want the top wall to reach down to the floor so as to add my 2D details as I have shown below.
Once the base-offset for both walls is at 0, the bottom wall disjoins and I cannot join them and it appears as below (Plan View)
How can I fix this?
How can I fix this?
drag the blue dot?
drag the blue dot?
This does not work.
This does not work.
Disallow join the two walls, stretch and join geometry manually.
I used beams instead of walls to get around the issue.
