join command
join command
warto1699
join command
warto1699
i created a 2x1  family using structure beam and i created another one using structure column profile. i loaded both the beam and column in but cant join them. i cant even select them... what am i doing wrong?
simmonsEDP9W
by their nature, i don't think beams and columns will join.
Sure they can join.  Share the families here.
mdb
Make sure you have set the Coarse checkbox to checked in the Visibility/Gaphics Overrides of the Element you wish to join.
warto1699
Awesome. Got it. Also started customizing material takeoff sheets. Is there anyway get cut angles on beams and columns. Like if I mitre them at 45 degrees can I get that show up in material takeoff
mdb
I have no idea about that.
Perhaps it would be best to accept my previous answer and start a new topic so that the question relates to the topic
