Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wall joins
4 REPLIES 4
markkibui101
233 Views, 4 Replies
Wall joins
markkibui101
I have two different wall types, one goes up by 200mm, the other goes up to the roof as I've shown in section view below.
I want the top wall to reach down to the floor so as to add my 2D details as I have shown below.
Once the base-offset for both walls is at 0, the bottom wall disjoins and I cannot join them and it appears as below (Plan View)
How can I fix this?
Wall joins
How can I fix this?
4 REPLIES 4
ennujozlagam
in reply to: markkibui101
ennujozlagam
drag the blue dot?
drag the blue dot?
markkibui101
markkibui101
This does not work.
This does not work.
Disallow join the two walls, stretch and join geometry manually.
markkibui101
markkibui101
I used beams instead of walls to get around the issue.
