Title block label
Title block label
PrathapSekar
Title block label
PrathapSekar
G'Day!!!
I've created one Title Block family for our project, in that family I've 9 Rows and 5 Columns, For each cell I've created each parameter to enter value.
What I want to know is, This process took me to create 45 parameters to fill 'Reference Drawing' only (Image shown below).
Is there any option to create a single parameter to control values of each cell. i.e., I want to create Sl.No, DWG.No, Title, Date, Revision instead of Sl.No 1, Sl. no2.....
Please let me know to if need more details.
Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
You may want to check dynamo.
If my answer solved your problem , Please Kudo  and Accept as solution.
MostafaElashmawy
As I know , no easy way.
Mostafa Elashmawy
