Tapered Column and Beam
Message 1 of 10
Hello All,
I am trying to create a tapered mainframe column and beam system.  I have done many searches on this issue and have not found what I want, at least not the easy way.
I found a tapered column family and it seems to work the way I want it to.  I have then created a tapered beam from the family ootb file Structural Framing – Beams and Braces.  I have changed some of the parameters since I didn't all of them.
Then I created an extrusion using blend –>>(base) beam attached to column -->> (top) beam end.  I attached some parameters within the blend.  This is working the way I wanted (I think).  Now I insert the beam as a structural framing component and pick the grid line and lock it.
This image shows a space, which I did intentionally..this configuration works when I change the dimension of the grid spacing...
Before I did that, I created a named reference plan for the top of the beam to align to.  That seems to work.  I want the column and beam to be on the grid line and locked to it so I can change the grid spacing and they move with it.
But.....
Then I try to move the end of the tapered beam to the face of the tapered column.  I do not attach or align, I just move it to where I want.  After doing that, I try moving the grid line BUT this is what happens.
Any ideas?  If you need more detail of what I did, feel free to ask.
OR - is there a simpler way of doing this or is this part of the program to make these?
Thanks in advance...
Jleibold
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
You may consider doing this by Cut command.
Example:
Rafal Gaweda
Message 3 of 10
The video looks amazing but I cant find the "Extention" tab.
Any ideas?
Regards
Message 4 of 10
ryanKVSBP
What revit extension is used in this video?
Message 5 of 10
ashwania426
Community Visitor
Community Visitor
Hey,
i have created a parametric tapered column using blend...but when i tried to apply base plate on it , it is not accepting any solution for this??
Message 6 of 10
Ignus.E
Hi. You would need to build a base plate connection family using the normal Revit family creation way, as tapered columns and beams is not supported by the Revit connections
Message 7 of 10
ashwania426
Community Visitor
Community Visitor
Hey. thankyou sir for this information
Message 8 of 10
hcooperdesign
Community Visitor
Community Visitor
Hi Rafal,  I am also interested in creating tapered beams easily, as you are showing in your video.  I am curious where did you find the "content generator" plug in for this?
Message 9 of 10
hcooperdesign
Community Visitor
Community Visitor
Hi Rafal,  I am also interested in creating tapered beams like you show in your video.  I am curious, where did you find the content creator plug in you are using?
Message 10 of 10
Ignus.E
This was from a plugin in called Extensions which is no longer available
